Bedlam
Jul 27, 2018Moderator
StableLoads will preload your OEM springs sooner at the OEM spring rate. SuperSprings will give you additional spring rate.
If your ride is too harsh with the SuperSprings but you get too much sag with just the OEM springs, the StableLoads will compensate for that sag with the preload. I think unloaded ride will be better with StableLoads verses SuperSprings for this reason.
I don't remember how your SuperSprings sit on the OEM spring pack. If the OEM overloads still make contact with the frame perch pads you may be able leave the SuperSprings in place and install the StableLoads. SuperSprings come in one and two spring capacities and also have a preload adjustment, so you may be able to go down to one one spring or no SuperSpring once you try the StableLoads.
44,066 PostsLatest Activity: Apr 10, 2026
