When I had a 29ft TT at seasonal site, I would:
- Install flat boards under its wheels - to reduce TT from sinking into the mud (from normal rains). Re (under my boat trailer wheels):
- click here - - For more stabilization, I would lay flat patio stone down, then cement block, then wood, then use its corner jacks. Re:
- click here - - For less floor bounce, I would install 6-ton floor jacks down its main frame rails. re:
- click here - Note: The purpose of above jacks (corner and frame's 6-ton jacks) was to add "support". They aren't made to "lift" off its wheels/axles.
This worked for my "fixed position" setup....
