aluminum.flyer wrote:
OK, you convinced me that the Progressive Industries is the way to go.
Yay!
If I could add one small comment. That is on the grounding inside the hardwire EMS, they provide a small terminal to connect the line and load ground wires using the provided crimp-on connectors. Seems a bit on the flimsy side and like it could loosen over time. I connected the line and load wires using a red twist-on marrette connector and ran a 3rd wire the same size over to the terminal and then used the provided crimp-on connector to connect to the terminal. But that may just be me being an EE and wanting to do it a better way. You'll see what I mean when you have it in hand.
