The typical failure of the vacuum breaker is a small amount of water seeping past the o rings in the valve and making it past the vacuum inlet. This results is a little water making it to the floor after filling the bowl and not so much from a quick flush. The fact yours sprayed water once put back in operation is most likely from freezing and cracking.
I did have to replace mine twice but the last one has been in there several years. In talking with Thetford several years ago when replacing for the second time I was told a change was made to address the problem. Since then it has been fine. Either way this does not seem to be what your problem was. Pink stuff is your friend.
