Bedlam wrote:
Most 3/4t trucks come with rear tires and rims rated over 6000 lbs, most 1t SRW's come with wheels rated over 7000 lbs and most 1t DRW's come with wheels rated over 10,000 lbs. Most of the SRW trucks are about 3000 lbs empty on the rear and DRW trucks about 3500 lbs. This gives you a good idea what each can do for payload in stock configuration. If buying a truck, match up your desired payload and you're done. If you already have a reliable truck, know where your weakest link in the rear axle assembly lies if you need a boost in payload. If the payload is so great that jumping up one class of truck through component upgrades will not help you, it's time to think about a smaller payload or a bigger truck.
Great post!
My 2500 came with the same tires as the 3500.  While the front axle/suspension and  rear axles were the same, the rear suspension wasn't which is why the 3500 variant of my truck a RGAWR of 7,000 lbs while my 2500 has a 6,500 lb RGAWR.  Everything else on my 2500 truck from the frame to the brakes is exactly same as the 3500.
So a 500 lbs difference in RGAWR equates to a 1,700 lb difference in GVWR and payload?  I am not a math genius, but that doesn't add up.  There should only be a 500 lb difference in GVWR and payload between the 2500 and 3500 going by the lowest rating of the individual parts yet there is a 1,700 lbs difference.  This is why I have no qualms with loading my truck with 1,000 lbs more than it is rated for.
