Campinfan
Aug 04, 2021Explorer III
My old trailer had a sticker where to put the mount. You may want to look directly below the sticker and tap on the walls in the area. You may feel or hear that it is a little different than the surrounding area because on some rigs, they mount a piece of plywood behind the wall to anchor the mount to. You can always measure to see how far back the pocket door goes. This was the same set up as my trailer was. You can also attach a thin piece of plywood to the outside of the wall if you can find the studs in the wall. I would paint the wood white or something similar to the wall so it does not "stick out like a sore thumb". I mounted a small tv (think 24inch or less) and they are really light.
If you can take a photo of the area and post it, it might help. Keep us posted.
