flyfishing48 wrote:
It would seem to me that if the rear of the truck goes down.....then front has to come up. And it in fact does.
So if the front is moving up it must be now lighter.?
Though in my example of 2" , there would be very few pounds difference I would think.
Not necessisarily, the front axle is just another pivot point. If your thought was correct, then adding even more would cause the front end to lift off the ground. Not likely although it could happen if the 5th wheel hitch location was behind the rear axle.
