Boom2
Jul 14, 2016Explorer
Suspension aids
I have a 2014 Silverado Z71 double cab that when towing my tt sags if I load some extra camping gear (bikes,firewood,canopies) just some added items. My question is what type of addition is recommende...
Me Again wrote:I remember when member Sleepy cracked the frame of his 1/2-ton pickup right above the rear axle, from carrying a heavy truck camper with air bags supporting the weight in the middle of the frame. Cracked right through the bolt holes in the web of the frame that the upper air bag brackets were mounted through. I can't recall if it was a Dodge or a Chevy.
Another issue beside being over loaded on tires, is smaller frames are not designed for the forces over the axle are not design for the load that air bags can transfer to that point on the frame rails. Chris
