Camper_G's avatar
Camper_G
Suspension problem after axle relocation (flip) need help
Hello,
I got my axle relocation completed last weekend, but only got it down off the blocks and back on the tires today.
For some reason, my spring shackels/spring equalizer plates are not sitting level the way they used to.
I tried jacking it back up, but the equalizers seem to want to sit this way. Both sides look exactly the same.
Here's a picture of what I'm referring to:
Can anyone shed any light as to what is going on or what I did wrong? I followed the instructions and everything went well so I have no idea how to correct this issue.
Any help or suggestions would be very much apprecaited!
Thank you,
Greg
  • Easy way to resize pics: Enter "500" in width box when you paste image URL in. (Or any number up to 640)
  • Camper G wrote:
    Hello,
    Thank you,
    Greg
    First size the pictures so they can be view on something smaller than a 50 inch screen…
    Then mount the shackles on both side in the up position…
  • Jack the frame up. Pull the center bolt out. Lower the frame enough to allow fitup with the equalizers up and install bolt.
  • Yes.. thats correct...but I had it that way when I put it back together...when I jacked it up to put the tires back on....it went that way for some reason?
    I dont know how to correct it?
  • Your shackle on the left side (picture) of the equalizer is on the wrong side. The spring should be above the equalizer like it is on the other side.
  • I added a thumbnail, and deleted the large view .
    If you click on the thumbnail it will take you to photobucket and there is a normal sized image there. I don't know to post a normal size image here, just the big one and the thumbnail. Sorry.
  • Your picture is way too big. Please resize per the forum guidelines (640x480) so we can make it out better.
