OP here...Found old posting with numbers.
Is this 2001 Dodge Diesel?
What does front axle weigh (4800 +)??
Bottoming out is weak springs/broken springs.
Yes I'm going to inspect those rubber blocks to see if they have been rubbed or broke even if they are there
I did find actual old numbers. (Memory is going???)
Pick up (2001 Dodge 2500, 5.9 Cummins, 8 foot bed, 2 wheel drive and SWD)
Front 3820 (GAWR 4500)
Rear 2860 (GAWR 6084)
Total 6680 (GVWR 8800)
Pick up and Trailer (Arctic Fox 25W, 2013 model)
Front 3720 (lost 100 pds?)
Rear 3780 (added 920 pds)
TT 7880 (Tandem axle, tires & rims max 2830 pds @ 80psi)
Added tongue weight to pick-up of 920 pds or 11.5% percent.
-Eaz lift (elite) weight dist hitch system (spec’s from manufacture)
Max Tongue weight 1000 pds (I’m OK, but getting close)
Max gross Trailer weight 10,000 pds (I’m OK)
-Receiver mounted on pick-up (spec’s taken from label)
Max tongue weight 1,000…. (I’m OK, but getting close)
Max weight 10,000… (I’m OK)
