TxGearhead wrote:
54suds wrote:
to install lowers I jacked the pressure off rear tires using the the hitch as the lifting point this opened a gap between the spring pack and the lower over load
Good thinking. Do you do this every time you load the camper, or leave them in all the time? I don't think it would take 10 minutes to jack it up and swing the stable load in. Hmmm...
once installed I have never changed them ( they Do HAVE a quick disconnect feature ) on this particular truck I added several up grades that were not needed but MAY help in a panic situation. I only added air bags to correct headlight alignment in loaded /unloaded night situations.
