AH64ID
Mar 05, 2014Explorer
I will look at the info. I will be taking the weight off soon enough to install some Centramatic's on the TT. I have looked into some AL-KO info and a 34" spacing is listed as an option.
The equalizer is ~6.25" vs the normal 5.625" length on Dexter. I don't know if that effects the spacing, or if the shackles absorb the difference.
I would really like to install the EZ-Flex, but not if it will lower the trailer, I get into some pretty rough places where I am within 1/4" of dragging. At a minimum I will do wet bolts and new bushings.
They use the Trail Air's. I actually stopped by the local dealership today to look at some. All the new non-rubber ones are 6.25" between bolts on the equalizer and the rubber ones were 5.625".
I did also talk to ORV this morning and they couldn't tell me if they where compatible or not.
brulaz wrote:
Outdoors RV puts rubber Equalizers on its higher end models. Not sure which brand. You might give them a call and see what they use and whether it would be a drop-in replacement.
