ScottG
Mar 05, 2014Nomad
ah64id wrote:
Thank you.
Did you replace all 4 spring bushings, and the 3 on the equalizer?
Yes on the springs but the equalizer already had metal (bronze?) bushings so I just added wet bolts there.
One tip, run grease through the wet bolts before installing them to make sure they are fully drilled. About half of mine were only drilled deep enough to press the zerks in so there's no way I could get grease all the way through (made in china..).
Talk about frustrating!
