AH64ID
Mar 05, 2014Explorer
Alright so I measured everything out. My hangers are spaced at 29.5", normal for a 33" spaced axle. My equalizer is longer than normal, as discussed. See the link below.
Based on the EZ-Flex I can run the standard kit and I won't lose any ride height. My equalizer is about the max one can have for a direct conversion thou. Max length from mount hole to shackle hole is 4", I measure 4". Max spacing between shackle holes is 6.25", I measure 6.25".
A K71-642-00 will be ordered momentarily.
Thank for the help.
http://www.sturdybuiltonline.com/Boat-Trailer-Galvanized-Equalizer-Bar-6-14-inch-EQ-356_p_612.html
EDIT: I found my part number listed for AL-KO applications and it is listed for slipper springs, so I wander why it's on my camper?
Thank for the help.
