Bankoske wrote:
Thanks for the feedback. Let me expound a couple items...
Our family of 5 consists of my wife, my 11, 7, and 3 year olds which adds about 600 lbs to the vehicle's gvwr. The max tongue load for the older Expedition is 920 lbs and the tow weight is 9200 and the 2018 is 930/9300. The GVRW of the Expedition varies from 1700-2000 lbs.
If you bumped the tongue weight to say 850, added the 600 lbs from the family, and another 300 lbs of "stuff", we would be right at the limit of the gvwr but would still be well within the limit of towing. That said, if we were mindful of the situation, we could also load the gear in the trailer itself and stay well below the tow weight.
Thoughts?
Jeff
Have you checked axle weight ratings on those vehicles?
The trailer you bought is a big guy. It also has metal siding which is not very light either. You will eventually find out that trailer weights (dry) fall under the same category of the tooth fairy and Santa clause. IE: Very fictional
Dry weights are just that, the trailer with nothing inside. No propane. No food. No battery. No water. No pots and pans. No bedding. No TV. I am not sure if they even include the AC unit on the roof. A good rule of thumb is to take the dry weight and add 12-15%. Your wet weight may very well be close to 8500 lbs.
I personally like to travel with our home water (city water) in the tank as well since it's chlorinated and won't stink up if left in the camper. For us, that's an extra 300 lbs. Sometimes we can't get to the cleanout so we just do it at the next trip. Could possibly add another 500 lbs in gray/black tanks.
Also, hitch weight is generally 12-15% of the trailer weight on a travel trailer. Once you throw your propane and battery up front. Fill up the front bunk with wood for levelers, sewer stuff, fresh water stuff, etc. Your 740 lb hitch weight will very likely be closer to 1000 lbs.
At that point, I think any SUV is out of the question as it exceeds their hitch weights and you are really pushing the limits on the tow rating/gvwr. You should really be looking at something like a Chevy Express Van.
A 2500/3500 will get you more seats than you need as well as almost a 10K lb towing capacity. As with anything. It is better to be within the limits of something vs right at the max allowed. I went from a Tundra (1/2 ton rating) to a 3/4 Ton Ram. It handles my trailer night and day better. I feel much safer towing with the heavier duty truck because it's well under the max limits. On paper, the Tundra was right at max, but within the capabilities of the trailer. And while it did tow it OK, it still pushed the truck quite a bit.
If I had a need for that many seats and was not interested in a truck, I would def. be looking at a heavy duty van.
