therobzilla
Oct 30, 2017Explorer
Ok,
I will add my experience with the Big Wig on my 2016 Ram 3500 Dually.
I have the Torklift Superhitch, I have Pac Spring airbags both installed on the truck already, I called and spoke with the factory before purchasing the sway bar, specifically about fitment issues with the aftermarket air bags and the Torkslift hitch.
The person I spoke with at the factory told me, "No Problem It Will Bolt Right Up No Fitment Issues".... I knew this was not really going to happen with the Torklift Hitch, but whatever I had to have a swaybar and a big one, with the exception of fabricating my own swaybar setup myself at our race-shop, I figured I would be able to figure out whatever was needed.
I bolted up to the axle no problem, however the links did not work as I thought with the Torklift Superhith, the saddle to hold the swaybar end did not align up correctly and the Superhitch was WAY in the way.
I had to fabricate an additional bracket to allow the links to be in double shear, and weld the brackets to the Superhitch and the frame on the truck.
Yes, there is some major fabrication needed to make the fit with Torklift Superhitch.
I had zero fitment issues with any exhaust components.
This addition to the truck is not for the squeamish or someone that does not have some fab skills or access to them.
This is for the Big Wig 1 5/16" swaybar with Superhitch reciver ONLY. I don't know about the other applications.
Rob
Rob
44,060 PostsLatest Activity: May 06, 2023
