Devocamper's avatar
Devocamper
Sway Bar fitment issues for Ram
Trying to find a sway bar for our new truck and wanted the Big wig like on our last truck but seems that there are fitment issues with the ram 3500 DRW when it has the gas engine due to the rear resonator location anyone have this issue ? Some fitment charts actually say diesel only. Anyone have good results/fitment with other brands? I did call Hellwig and they sounded like this is news to them but did repeat the diesel note
Thanks
Mike
  • It appears Roadmaster makes a rear sway bar for the 2017 with leaf springs.
  • finsruskw wrote:
    The Ram DW 3500 diesel is not fitment free either.
    On my 2015 I had to smash a dent in the tail pipe to clear the hanger as well as drill an access hole in the spare tire shield for access to the bolts on that side.
    ....and I thought hammers were only for fixing Fords.....;)
  • The Ram DW 3500 diesel is not fitment free either.
  • Someone else mentioned this and I was able to compare my father's 2016 diesel to my 2015 6.4. It does indeed appear to be the resonator causing the problem.
    Easy solution is to rework the tail pipe to either move the resonator back a few inches or just eliminate it complete. I would have to crawl back under his taking measurements of his Hellwig bar and then comparing to mine to be absolute sure along with figuring out how much it would need to be moved.
