AtomicChicken wrote:
BarneyS wrote:
Yep, you may be correct. That does look like a Dual Cam arm. I don't understand the chains in the picture then. They should be attached to the cams arms. The Dual Cam system does not use chains that are fastened to the bars. What is that thing hanging down on the right attached to the chain? It sure looks like a trunnion WD bar to me.
Barney
The thing hanging down on the right side looks like a friction sway bar to me but I could be mistaken.
I think it is the other WD bar. Looks like it has the cam hanging off the end of it. Not sure how it got in that position...But in a rollover anything can happen.
