Bucky Badger wrote:
campigloo wrote:
M GO BLUE wrote:
A Chevy Avalanche towing a 30' trailer???
X2 but the dealer and the tv commercial told me it will pull anything
What's the issue? It's the same thing as a crew cab short box truck that millions are towing with.
Agreed! I believe that truck is rated at 9500lbs. it has the same wheel base probably larger than an F150 rated to pull 11300 lbs. The set up looked ok. She could have dosed off woken up and overcorrected causing her to loose control. Shoot if I made a donkey move I'd tell authorities it was sway too. Good thing is they are ok.
