mikeratz
May 03, 2020Explorer
Sway Problem / Need Help
I am towing a 253RB Sunset Trail(30') with a F150 Ecoboost and am having a hard time with it if there is ANY wind at all.
For the most part it tows ok on a calm day but if there is any wind at all it feels very unstable in the back end and reduce speed considerably / "white knuckling" it.
I am using a Anderson hitch which I am debating on changing out with something that can transfer the weight better. I also added a Roadmaster suspension kit to the truck to help take some of the squat out.
I used this hitch on my last Sunset trailer which was a foot bigger so figured it would be fine. (Although we never had it long so maybe just never noticed) Tow vehicle then was a 2015 F150 Ecoboost with Goodyear airbags.
Current Setup
Trailer
2019 Sunset 253RB
Dry Weight 5531#
Loaded 6700#
2019 F150 Ecoboost
levelling kit
275/65R18 'E' Rated Duratracs
Roadmaster Active Suspension
Truck Only - 6063#
Front Axle 3395#
Rear Axle 2668#
GVWR 7850#
GAWR F-3750#
GAWR R-4800#
Truck & Trailer Combined
Front Axle 3110#
Rear Axle 3924#
Trailer Axles 5710#
I can't get all the sag out and am wondering if the Anderson is just too light for this setup and possibly what is causing it to feel unstable as well.
Any thoughts, hitch recommendations??
Current Setup
Trailer
2019 Sunset 253RB
Dry Weight 5531#
Loaded 6700#
2019 F150 Ecoboost
levelling kit
Truck Only - 6063#
Front Axle 3395#
Rear Axle 2668#
GVWR 7850#
GAWR F-3750#
GAWR R-4800#
Front Axle 3110#
Rear Axle 3924#
Trailer Axles 5710#
