TxGearhead wrote:
I have maybe a max of 3/4" clearance between my dually fenders and my front jacks. I have dually swingouts. I see where eTrailer has extensions to mount on the swingouts. Item # HJ54FR. It would position the jacks 5" farther out. I haven't done any measuring yet, but it will be real close having enough wire from the jack motor to the plug. Anyone using these extension? Any thoughts overall?
I wouldnt have any issue with the bracket its self, but if I did do that I would upgrade the bolts to grade 9 as it only uses three on each side.  the higher shear strenght will give you a little extra peace of mind.
Steve
