CA_Traveler
Jul 06, 2020Explorer III
GravelRider,
Consider a decent battery monitor so that you know the battery charge (SOC) and can better manage your loads and gen charging. There are $20 meters that can also help.
If your batteries are only being charged to 13.6V then they are signifcantly undercharged which contributes to your problem and this is common with to many RV chargers. Chargers during the bulk stage should raise the voltage to 14.4-14.8V. Following the bulk is the absorb stage where the voltage and amps taper down eventually reaching the float stage. 100% SOC takes a lot of hours so gen charging 50-90 SOC is generally used. OR morning gen charge and then solar finishes the charge. OR just solar except on overcast days.
44,071 PostsLatest Activity: Aug 16, 2026
