ajriding
Jul 08, 2020Explorer II
No, no, no... This Furrion given in links above is not a Danfoss-style compressor, it is not efficient. It draws 15 amps, the real camping-style compressor fridges draw 3-5 amps max and do not need a spike of electricity to get the compressor started either. There would be no point to put that in an RV unless you are always plugged in.
I have one of these ICECO Compressor Fridgehttps://www.wayfair.com/appliances/pdp/iceco-211-cuft-frost-free-chest-freezer-ieco1002.html Though you will have to search another site to find specs...
I have 2 GC batts and could easily go 3 days without use of solar charging. With solar this will run indefinately
5 amps draw is the max any compressor DC powered fridge should pull, typically 3-4 is normal, and they run a few minutes only before shutting off, having reached the cold temp. As I said... 8-10 mins per hour total of run time seems normal. You can insulate the sides and top to make it more efficient, but I have not needed to do this yeat.
Also see ARB and Dometic for other more popular models.
44,071 PostsLatest Activity: Aug 16, 2026
