TobyG
Feb 14, 2016Explorer
I don't know why but, things that should be simple always end up being the biggest pain in the butt.
So, I got the 3-way fridge into the trailer, took out the 30 amp fuse, hooked up the gas,plugged into the ac and then plugged in the 12v & ground. Went inside and there's no power to the display. First checked trailer fuse panel, then got voltage meter out and checked I had power at AC outlet, and 12v and ground. 119 and 12.8 respectively. Then I replaced the 30amp fuse just to make sure it wasn't that. Now, I'm going through the trouble shooting section and it tells me that I need to check the 3amp fuse but, I don't see any 3amp fuses.
So, any idea where the 3amp would be? Or ideas on what the trouble might be?
44,056 PostsLatest Activity: Nov 19, 2013
