CA_Traveler
Feb 15, 2016Explorer III
You've got a wiring problem and it can be the ground. Connect the negative voltmeter to a good frame ground. Measure the voltage to the negative battery post (should be very close to 0V) and positive battery post. That's post not the cable.
Repeat at the refer also using a good frame ground. You're trying to determine if it's the positive or negative or both wires that are the problem.
I'd disconnect the 12V heater wire just to be sure it's not the cause even though you have no display.
Maybe the refer is balking at 12.0V but you it should be very close to the battery voltage with the DC heater off.
44,056 PostsLatest Activity: Nov 19, 2013
