texasfifthwheeler wrote:
we are making a change in rving. we currently have a 33 ft 2005 nuwa fw but want to make towing and camping simpler. we only used the fw for local trips four to five weeks a year. it appears the pop up brands have changed since we had a coleman in the late 70's. what brands do you recommend as a quality unit? we are just now beginning our search and find a lot of different styles and floor plans for such a small space. any suggestions would be most helpful.
So many take overs have happened over the years, it's hard to recommend anything since Forest River pretty much owns all pop up brands except Jayco which also owns Starcraft.
I can tell you what not to buy.
I'd stay away from Starcraft if they are still using Aqualon tenting. Even though it's rugged, it has a memory when stretched and will leak. I had to have both bunkends replaced on my my 2007 2406 because I had it up in the snow. I'm guessing, but the snow must had stretched the material as the water leaked after that at all the seams.
Aqualon is a material soaked in vinyl so it is thick and doesn't stretch much. SO I'm thinking this material has no gives. I should had tried wax but instead tried seam sealers, ALL, which all failed.
I also would not recommend Rockwood or it's sister company Flagstaff. Just so many issues with build quality. I had it only 1 year because it was falling apart. It was a 2005 but had frame problems, floor problems, cabinet troubles, electrical troubles, just wasn't worth the stress. It did have a leak free tent that wasn't very tuff and did get tears easily (unlike Aqualon) but it was able to stretch easily and had no memory. It never leaked 1 drop of water.
After the 2007 Starcraft pop up, I went to a travel trailer. I just had to many problems with pop ups and the wife didn't like pop ups. Myself, I really like them, just not the issues.
While I never noticed it while having the pop ups, I noticed this while looking at some 2013 Jayco highwall and low wall pop up, that the counters, sink, and stove are lower than in the 2 travel trailers I owned. Not really low but definitely noticable.
Also Pop ups are just as expensive as many larger travel trailers but have less features and minimal amenities as lack of a freezer, oven, central air/heat, and the such. Not a big deal but they should be much cheaper since these features are missing. BUT the lift systems and tenting must cost a lot. My 2008 Jayco Jay Flight loaded travel trailer was only about $1000 more than my 2007 Starcraft pop up but had so many more 'expensive' features.
Also, do not get a water heater without DSI. It was just a major pain lighting the pilot out in the wind. DSI, you turn it on and do nothing else. Also if you can, get one with an electric option, it saves propane that you can use for heat.
I really liked the layout and interiors of the Viking/Coachmen twin pop ups and the Palomino pop ups but I've noticed that they started making them cheaper with Forest river Rockwood features as butyl tape for the roof seams instead of silicone caulking.
Good luck in what you choose.
