_1Flyboy
Jul 10, 2023Explorer II
valhalla360 wrote:…. I would think that NO maintenance & NO acid spilling in the battery compartment & NO acid fumes would be a BIG advantage over regular FLA batteries!…………#1Flyboy wrote:
….. I’d recommend 2 - 6 Volt AGM ( No adding water, No acid fumes, Maintenance free, can mount in ANY position, Lasts Longer, proven technology, etc., etc. ) batteries
Unless you plan to roll the trailer, not much advantage with AGM and a lot of extra cost. Boil an AGM and there is no putting more water in, they are simply trash. Standard 6v batteries that are not abused should be good for 6-10yrs.
As to the OPs suggested batteries, they should be a nice upgrade over the current starting batteries (which are simply re-labled as marine or dual purpose). 6V batteries are true deep cycle designs.
Side note: It does seem odd that the 20amp rating is 230amp-hr but the 5amp rating is 174amp-hr. Typically, the slower you pull the amps the more amp-hr you get out of a battery.
