HMS_Beagle
Jul 13, 2023Explorer II
I would never go back to flooded lead acid batteries, just due to the inevitable corrosion. However AGM batteries do have to be correctly charged, or their life will be short. That means correct voltages, and for sufficient time, somewhat frequently.
There is an argument for two 12V vs two 6V: if you run an inverter with high current draw, the two 12V batteries will have lower internal resistance than two 6V, and so lower voltage drop while running the inverter.
