deltabravo
Jul 20, 2023Nomad
valhalla360 wrote:
If your charger is causing large amounts of gassing, fix/replace the charger.
High quality chargers (3 stage units) that I use do cause some gassing of flooded wet call batteries.
Every RV I've owned, I disable the stock converter and use an inverter/charger for my charging needs.
With the minimal space in an AF truck camper battery compartment above the batteries, a "filling system" isn't going to solve the issue of not being able to check/fill the batteries.
