rb2boxer's avatar
rb2boxer
SWR 5th wheel towing
I am really getting close to pulling the trigger on a Chevy 3500 Duramax crew cab short bed. This will be my first diesel and hope I can pull it off. I current have a 2500 gas. We want to upgrade to a fifth wheel in the not so distant future. We are not full timing however we would like to take some longer trips. The truck will mainly be used as an all around vehicle which is why I am leaning toward SRW. I really don’t want a Dually although I’m sure when towing it’s the ultimate.
How do your SRW short beds handle the 5th wheel? I would obviously buy a trailer within the specs the truck could handle. See a lot of SRW out there pulling them.
  • mine tows great, mine handles the pin weight great, mine stops great..I AM AT MAXIMUM ratings, but not over axle rating or tire ratings, which by the way in my eyes are the 2 important numbers...
    2015 F-350 SRW towing a 2020 Redwood 3991 RD at 16K
    ** edited for spell check !
  • The big question is how big of a 5er are you getting?
    Take 25% of the GVWR of the trailer and check the payload (including weight of people and gear in the truck)...If the payload rating of the truck can handle it, you are probably OK (check the other ratings but this is usually the limiting factor)
  • There will always be two sides to this, Dually or SRW. But, you'll be like us and use the truck as a full time vehicle. GET A SRW!
  • lenr's avatar
    lenr
    Explorer III
    We just stepped up to a 36' 3" fifth wheel on our Ford F-350 SRW Diesel, crew cab, short bed. 10,780 dry, 12,660 loaded ready to camp (full fresh water tank), with 2440 pin weight. I'm comfortable because we installed 6000 lb. axles with disc brakes. But that is it--I would not be comfortable with any more weight even though Ford says we are good for a 14,500 fifth wheel. We are just below the rear axle rating and tire rating--so OK, but no room to spare. SRW is going to save money on tires and initial cost. If looking at longer, heavier, or toy hauler trailers, MHO is one is in dually territory. Toy haulers tend to be nose heavy to allow for the heavy toys in the rear, and really cry out for dually. I was honestly surprised how close we got to our weight limits on axle and tires after we got this trailer. In terms of handling, the SRW crew cab short bed handles this trailer just fine--comfortable in emergency moves, and the disc brakes will stop a freight train after a short delay to build pressure. Our trailer has dimples that allow for tight turns without bumping the cab, so short bed is not a problem, although we have a slider hitch form the prior trailers.
  • I'm pretty sure the GVWR for the 19 GM 3500 srw is 11,500. The new 2020's, which are supposed to start hitting the dealerships this week, will be 12,250 from what I've seen which should increase the payload capacity. I've looked pretty close at them, on line, and have been impressed with what is being offered. There is a down side: more money and I would not really want an early production model.
    Look at the little yellow sticker on door pillar and it will tell you the payload capacity for that particular truck. I really don't like driving a dually either but I could not find a truck in a srw equipped like we wanted that would handle the close to 4K pounds of weight we add to it. We have about 3100 pounds of hitch weight which the factory said was 2685. The rest is us, a fat Boston Terrier, 25 gallons of extra fuel in a transfer tank, the hitch and other odds and ends. It adds up quick once you start putting your stuff in it.
  • Mine is a long bed 350 SRW but it tows my 35’ high profile 5er great. Very stable even in high cross winds. Good friend (RIP) had a short bed 3500 SRW and was equally satisfied. As long as the weights are good the SRW will serve you well.
    A dually is only required if the weights dictate it.
  • My Ram 3500 does a great job towing the 5er in my sig. 41 foot and weight is 13880 loaded and 3060 pin weight.
    Mike
  • Our 2015 Silverado HD 2500 (diesel) does great pulling our 36-foot 5th that has a dry weight of 11,700 and dry pin weight of 2100. If we had gone with the 3500 we would have had some pounds to spare in terms of payload, but the 2500 does fine being a few hundred pounds over on payload.
