gmcsmoke
Mar 30, 2014Explorer
GM uses DEXOS approved oils, conventional/synthetic blend, in engines that spec it. You make it sound like it comes factory filled with a better blend and by running conventional you're doing a disservice to your engine.
if your engine specs conventional run conventional. get a oil analysis with a tbn if you're that worried about it.
44,068 PostsLatest Activity: Apr 17, 2021
