intheburbs
Mar 30, 2014Explorer
CKNSLS wrote:intheburbs wrote:
I run synthetics for peace of mind.
Really cold weather? Synthetic is better in the cold.
Driving 500 miles in the middle of summer? Synthetics handle heat better.
Longer vacation than planned? Synthetics handle longer change intervals better.
As previously said, conventional oils, when changed at the proper intervals, work just fine. Synthetics are just better. I'm willing to pay extra for that.
BTW, I use Royal Purple. Some Walmarts carry it - $8.49 a quart. As hard as I work my truck, I'm willing to pay the extra cost.
Conventional oil was used by those in Alaska for years before synthetics came along. Conventional oil performs fine in the summer in extreme heat. YOUR MOTOR WILL NOT LAST LONGER USING CONVENTIONAL OIL VS. SYNTHETICS. 99.5% of synthetic users never use their oil to it's maximum OCI.
Spend some reading time over at bobistheoilguy.com.
Yeah, right. I've been on that site. They have oil wars just like Ford vs Chevy or 9mm vs 45 on other fora. Some good info, but still a high signal to noise ratio.
From my owner's manual:
If you are in an area of extreme cold, where the
temperature falls below ?20°F (?29°C), it is
recommended that you use either an SAE 5W-30
synthetic oil or an SAE 0W-30 oil. Both provide easier
cold starting and better protection for the engine at
extremely low temperatures.
I'll listen to the manufacturer, thank you very much. Also, why does GM recommend synthetic oil for the axles?
44,068 PostsLatest Activity: Apr 17, 2021
