Jayco23FB's avatar
Jayco23FB
Synthetic Oil for Towing?
I have a 2007 Chev 2500HD 6.0L gas with 36K
Are there any benifits of using say Mobil 1 5w30 synthetic for the towing season? Or is regular 5w30 just as good?
  • DKean wrote:
    https://www.mobiloil.com/USA-English/MotorOil/Car_Care/AskMobil/Towing_While_Using_Mobil_1_Synthetic_Motor_Oil.aspx
    This is good information. Thanks for the post.
    Question:
    If Towing Prevents the Use of Mobil 1 5W-20, Identify the Correct Oil
    I just purchased an '06 Ford E450 motor home with the V10 engine, I noticed on the back of the Mobil 1 5W-20 synthetic it said that it was not good for towing. I use 5W-20 in all of my trucks. What should I use as a specific oil for this motor home?
    -- David Hinsley, Conroe, TX
    Answer:
    The comment indicating the Mobil 1 5W-20 is not recommended for towing refers to our Mobil 1 Extended Performance 5W-20 product with extended oil change intervals of 15,000 miles. ExxonMobil does not recommend extreme drain intervals for vehicles involved in towing, racing and commercial services as they tend to be severe operating conditions that require more frequent oil change intervals even with a high quality synthetic engine oil. If your vehicle recommends a 5W-20 engine oil then Mobil 1 5W-20 will provide excellent performance. Otherwise, use the viscosity recommended in your owner’s manual.
    Clicky
  • How often do you change your oil? It appears you don't put many miles on your truck so I doubt you will reap any benefits for paying a higher price for oil.
  • Synthetic will not Break down as quickly as conventional oil, so for peace of mind I would go with that.
  • https://www.mobiloil.com/USA-English/MotorOil/Car_Care/AskMobil/Towing_While_Using_Mobil_1_Synthetic_Motor_Oil.aspx
