SUKISHORT
Nov 26, 2014Explorer
Synthetic oil
I have a 2005 Dodge 1500. 5.7L Hemi. It has 73000 miles on it. I have kept the oil changes and maint. Very current. I am thinking of changing to a synthetic oil for my next oil change. Is it wort...
ib516 wrote:myredracer wrote:
My BIL owns an auto parts shop and told me that synthetic oil is thinner. Not sure if that's a myth or true.
So is it true that if you switch to synthetic at some point that you can end up with leaks you wouldn't have had otherwise? I know dino oil thins out with temp. but I thought synthetic has relatively stable viscosity with temp. changes? Maybe it's that synthetic has some other properties that cause it to leak more?
I've thought about switching to synthetic in our F250 but I sure don't want to end up with a leak, but maybe there is no major advantage anyway.
Here's are some facts:
Synthetic oil isn't "thinner" than regular oil, given the same viscosity grade (5w30 to 5w30 for example).
Synthetic oil doesn't cause leaks.
Synthetic oil is superior to conventional oil in every measurable way, other than cost.
Here is my opinion:
You have to decide if the benefits outweigh the cost in your situation and intended use.
Again, just my opinion, but in extremely low (-30*C or colder), or extremely hot/high load applications, it's worth it to use synthetic.
