SUKISHORT
Nov 26, 2014Explorer
Synthetic oil
I have a 2005 Dodge 1500. 5.7L Hemi. It has 73000 miles on it. I have kept the oil changes and maint. Very current. I am thinking of changing to a synthetic oil for my next oil change. Is it wort...
wintersun wrote:
Most synthetics for diesel are not available in a 15W-40 grade which is also what is needed for temperatures above 0 degrees. A 5W-40 oil in temperatures above 0 degrees is not going to provide nearly as good protection in warmer temperatures. One is already sacrificing lubrication performance with a multi-grade oil with polymer shear which is most evident when oil is forced into the main bearing journals of an engine.
