SUKISHORT
Nov 26, 2014Explorer
Synthetic oil
I have a 2005 Dodge 1500. 5.7L Hemi. It has 73000 miles on it. I have kept the oil changes and maint. Very current. I am thinking of changing to a synthetic oil for my next oil change. Is it wort...
Sport45 wrote:Hannibal wrote:GoPackGo wrote:
I saw 245 degrees oil temperature when towing my 5th wheel on those long uphills in the Rockies this summer. It normally runs about 205 degrees on the flats.
I run full synthetic oil.
That's why I use it down here in Florida and around the southeast where heat is a consideration. Just incase the oil reaches 300*F in the journals or wrist pins or even the valve guides while towing our 5th wheel in the heat of summer. Probably doesn't but, I sleep better knowing it's in there just incase it does.
245 or 300 degrees? Thats not hot enough to cook French fries, I doubt it's hurting your bearings.
