AH64ID wrote:
snip....
I even had to add additional ZDDP to my oil for cam break-in.
Cummins still uses flat tappet cams in 2014, but they do come OEM with synthetic... but diesel oil has a LOT more ZDDP than gas oil, even the CJ4 stuff.
All of the cam break in grease I've ever used has MolyB, ZDDP and
some even graphite filled
There are discussions of Molyb being a metal ash and abrasive. Correct
but out of context...Molybdenum Disulfide in lubrication has to of
the right particulate size to work properly. El Cheapo cam lube uses
too large a particulate size and it is abrasive.
El Cheapo, as Molybdenum Disulfide is one of the most expensive
components for any lube. Whether liquid or grease. I now use Tungsten
Disulfide, but may change back The natural plating attributes of
Tungsten isn't as high as Molybdenum (dry starts)
The whole point of that is to SLOW down the wearing of mating parts
until it has had a chance to 'lap' the mating surfaces together. Why
they add super lube additives like Molyb
Flat tappets are 'rotated' by the cam lobe to keep the wear evenly
spread over the surface.
The higher ZDDP is because SMOG components dictated lower ZDDP in the
engine oil. So as to NOT poison the CATs so quickly
Before rollers on the CAM, the higher ratio rockers and higher spring
rates had the push rod angle increase ever so slightly...that added
loading to the lifters to its bores. Not the case these days, nor
is changing out a CAM much of an option
