naturist
Aug 21, 2020Nomad II
Nope. No can do. The control valve is part of the regulator. The office is not part of the regulator, it is used to inject a stream of regulated gas into the air in the mixing chamber. Because the control valve is part of the regulator, this device is not a good candidate for use on the low pressure propane system on your rv. It could work if you put a Tee in the high pressure line, but I don’t recommend that.
44,070 PostsLatest Activity: Sep 18, 2026
