Kayteg1
Apr 27, 2020Explorer II
Oldskoolsteve wrote:
Does the power (+) from the 7 way (the truck) plumb directly to the battery and trickle charge when the truck is running? I don't think its more complex than that? Usually trucks have 30 amp charging wire, so that is more than a trickle. Some campers have built-in battery separators with fuse
The power (+) from the truck 7 way then disconnects upon turn off leaving the camper system independent, correct? From what I read, only Ford does that. Other brands have no power disconnect
Add in my 3 way fridge. Where would the 12v (+) & (-) hp in the 7 way cable?
It goes from camper battery. All you have to do is push the button on control panel
Forgive the ignorance, it seems very simple...but I don't want to screw it up!
Thanks in advance
44,056 PostsLatest Activity: Jan 12, 2020
