1stgenfarmboy
May 01, 2017Explorer
Downwindtracker2 wrote:
I did an axel flip on our TT, it was the only way5200# would fit, and had sway problems. It wasn't the fish tailings most call sway, rather the flopping side to side with ruts in the road. I had both a smaller TT and a 3500 Dodge.
Most RVers do silly things with the hitches rather than face the fact it's a suspension problem. I learned that with a Cherokee and a tent trailer 30 years ago. On our TT, I solved it with anti sway bars. We had shocks on the TT so I didn't have to add those. That would be the first step, it may be enough. On the TT I used a 48"x16"x1" anti-sway bar and on the truck it's a aftermarket 1 3/8". I'm able to blithely cruise up the heavily rutted "Cog" at 120KPH, I also switched to Michelin truck tires. I use a truck camper in hunting season so I needed a sway bar on the truck. Remember TT suspensions are only one step removed from the wagons used on the Oregon Trail. Dodge when they widened the frame on Ram thought that they didn't need a rear anti-sway bar, they are wrong. Even running empty, she handles much better.
I think this is your problem ^^^^^^^^^^^^^^^^^^^^^^^
I don't know how much higher your TT sits after the flip, but I would guess at least 5 inches +, that is more than enough to make the center of gravity high enough for top heavy lean.
My guess would be DWT have hit the nail on the head, my last camper was a masive TC in a 4X4 1ton DRW truck, I added every thing on the market to stop the top heavy sway, never could get it where we were comfortable with it so I went back to a TT.
44,067 PostsLatest Activity: Jun 05, 2026
