KevinBerting
May 01, 2017Explorer
Guy Roan wrote:
I think your problem is simply that you don't have most of your weight over the wheels.
You said that you have most of it toward the front. That is a mistake
Your trailer should be on the same plane as your TV.
Stand opposite and look and see if they are both parallel to each other. If your trailer nose is down or up, it will sway all over the place
Guy
The trailer rides perfectly level with the drop I added. It was slightly nose up (like an inch or so) originally. I corrected this after the first two trips, hoping it was the cause and the drop would fix the issue. It didn't. I try to load heavy items towards the front to increase tongue weight for stability.
44,067 PostsLatest Activity: Jun 05, 2026
