RCMAN46
May 01, 2017Explorer
What kit did you use for the new spring perches? Make sure the spring center bolt is centered to the spring perch hole.
Make sure you did not get the axle turned around. By that I mean the left side of the axle is still the left side.
The best thing right now is get the trailer and truck on the scales and do three weighs.
Truck only both axles.
Truck and trailer without WD active all axles.
Truck and trailer with WD active all axles.
44,067 PostsLatest Activity: Jun 05, 2026
