bobndot
May 01, 2017Explorer III
x2, Like myredracer said.
Kevin, when u installed your hitch, did you take wheel well measurements before and after you installed and set up your hitch ?
take a look thru David's hitch et up to double check your measurements.
I would start doing things that don't require you to spend money. (yet :))
Rechecking your tire PSI to max on the TT as well as the TV.
Hitch set up and weighing the trailer are the 3 things i would do first.
When you level the trailer to check the hitch set up, make sure you are on level ground and equally measure the trailers frame front and rear to the ground.
http://davidsrvtips.blogspot.com/2009/02/hitch-setup_2781.html
44,067 PostsLatest Activity: Jun 05, 2026
