Hannibal
May 04, 2017Explorer
Yes it will Downwindtracker2! The lightest bars you can get away with will give the best tow. If the trailer sits the TV down 2" in the rear and the bars raise it back up 1", it'll probably tow well. If you tighten the bars up trying to get the TV to sit like it does empty, you'll likely induce some squirrely steering. If your TT sits your TV down more than 3" without the bars, my opinion is you don't have enough TV with or without WD. Soft tires and aggressive tread or even new deep tread on HT tires can leave you squirming all over your lane with wind and worn pavement. If you load 500 lbs behind the rear axle of a vehicle not built to handle it, you'll feel the same squirrely steering without a trailer at all. Air bags will raise it back up to empty height but might even make the steering disturbances worse.
44,067 PostsLatest Activity: Jun 05, 2026
