KevinBerting's avatar
KevinBerting
Taken all the steps to prevent sway. Still swaying. Help!
I'm out of ideas and need help. I have been camping for 8 years in a pop up, and just upgraded to out first TT. I should mention that I drive pretty large commercial vehicles with buckets and outriggers daily and am comfortable towing large, very heavy trailers at work. I'm no rookie, yet I'm feeling at a loss here.
Towing our TT is a white knuckle experience everytime. A little wind or a passing truck is sending me into a fish tailing nightmare multiple times per trip. I have a properly installed and tensioned weight distribution hitch plus a sway bar. I am loading the trailer with as much of the weight low and forward as I can. I just put new tires on the trailer with proper inflation. The ride level is great with the right drop on my hitch. I have trailer brakes that are working well to slow it down as needed on declines. My tow vehicle is a brand new 2017 Ram 2500 with far more than enough tow capacity. Everything in my set up says I should be able to tow this thing easily and comfortably, yet I am constantly on high alert! What else could I be missing?
Our travel trailer is a 2010 Keystone Hideout 26 BH. 26 feet long plus tongue and no slideouts. Dry weight is 5100. I did flip the axles as soon as we bought it, because it sat very low and I wanted better ground clearance. I know this could affect stability somewhat, but considering my larger tow vehicle and WD hitch with sway bar, this shouldn't be causing that big of issues, right? The WD hitch is used. Is it possible the bars are bent or malfunctioning? They are the type with the chains hooking them to the trailer tongue. Could my sway bar just be shot? What else could possibly be going on here? I need to get this trailer moving safely down the road. I can't keep fighting it every trip out.
Thanks for your input. I'll try just about anything at this point.
  • Was this problem present before flipping the axles? If not, then the problem is possibly the alignment of the axles to each other and to the trailer frame and tongue. If sway occurred before flipping them, (I can't imagine why you would have flipped them before resolving the sway), then it would come down to not enough tongue weight.
    A trailer should be able to be towed down the road with no sway control mechanisms and not have a tendency to sway. If it does, figure out why. Afterward install the sway control system if desired for those tough conditions like strong crosswinds, less desirable tow vehicle, etc. I don't think the system itself is designed to resolve an issue with a trailer wanting to sway.
  • First thing I would suggest is verify that the axles are actually true. By that I mean measure very carefully from the tongue to each hub. When the axle flip was done it is possible who ever did the job misaligned them. Second do you have a friction sway control of some sort? Next I would weigh the tongue weight, and verify that your hitch is correctly setup. Especially so since you raised the hitch. It is possible that you have the hitch head wrong now.
