Jfet
May 21, 2013Explorer
talking insulation: spray-in polyu vs polyisocyanurate sheet
Putting this on a separate thread to my camper build because it may be of interest to those with existing campers they are restoring.
I was almost sold on spray-in polyurethane foam, done by a contractor, but I had worries about the fire hazard and the very toxic fumes that would kill you before the fire even got a fair chance. I do not know if these are overblown fears but I only have one life to beta test it. In homes they require a sheetrock type material as a thermal barrier...that isn't going to fly for our camper build.
In researching this more, I came across a long thread on an airstream forum about the downsides of spray-in foam. Two that popped out at me were 1)repair issues if you need to remove a sprayed panel, and 2) the foam turning into powder in non-stationary applications other than residential homes. I haven't finished the thread yet, but it gave me the idea of looking into polyisocyanurate sheets as an alternative.
The thread is here: http://www.airforums.com/forums/f46/spray-foam-insulation-46536.html
In looking for a polyisocyanurate sheet, I found DOW makes them with a aluminum facing and fiberglass reinforcement in a R6.5 rating for 1 inch thick. They are fire rated to not combust without an external source and can even be used in living areas without any thermal barrier at all.
DOW Thermax sheeting: http://msdssearch.dow.com/PublishedLiteratureDOWCOM/dh_08c3/0901b803808c3035.pdf?filepath=styrofoam/pdfs/noreg/179-07942.pdf&fromPage=GetDoc
What do you guys think? Any opinion?
