westend
Aug 27, 2016Explorer
Your OEM wiring is a daisy-chained parallel configuration. The wires are fed to one brake location and then proceed to each following location. The best remediation is to rewire the brakes in a Star configuration, a pair of wires or at least one power wire to each brake location. You can terminate the star wiring at a terminal strip in the front of the trailer and lead your umbilical wire to this terminal strip. If you install a pair of wires to each brake, and install the terminal strip, diagnosing an electrical brake problem becomes very easy. It can all be done from that forward terminal strip.
44,066 PostsLatest Activity: Mar 14, 2015
