stevemorris
Aug 28, 2016Explorer
being able to measure the brake current flow when fully energized is critical in assessing the condition of the wiring. other measurements like resistance and voltage at the 7 pin connector are valuble too but don't tell the whole story
the culprit is voltage drop. voltage and therefore current drops with length of wire, size of the wire and condition of the wire and all of the connections
when I was working on our tt brakes I measured the voltage at the "last" wheel, it was less than 5 volts but still 11 volts at the 7 pin.
adjusting the shoes at the backing plate will have zero effect on the electrical side of things, each magnet will still draw about 3 or 4 amps each depending on the size of the brakes
one magnet should show a resistance of about 4 ohms. if you have 4 brakes, then the resistance will be 1 ohm, remember they are in parallel not series. this resistance also varies slightly depending on brake size
moving the magnet and thus actuating the shoes with the drum off will only move one shoe. the other shoe is moved by the first shoe but that requires that the drum be in place and the drum rotating. best thing here is to make sure that they can move freely, drum brake lubricant should be used at the contact points on the backing plate and any other moving parts. just don't get it onto the shoe material or drum surfaces
I did do an entire thread on checking and rewiring brakes a few months ago, I learned a lot, more than I ever wanted to know about electric brakes!!
btw, 4 brake magnets with 3.2 ohms in parallel like your brakes will have a resistance of 0.8 ohms
1/Rt = 1/R1 + 1/R2 + 1/R3 + 1/R4
1/Rt = 4 x 1/R1
1/Rt = 4 x 1/3.2
Rt = 1 / (4 x 1/3.2) = 0.8
1/Rt = 4 x 1/R1
1/Rt = 4 x 1/3.2
44,066 PostsLatest Activity: Jul 25, 2018
