nickthehunter wrote:
If my dual axle trailer has a blowout I will proceeding cautiously, at minimal speed, up the next exit and to the nearest safe spot. I won’t be changing it on the side of the road while cars and trucks fly past at 70 mph. Which is the same thing that would happen if I had a single axle trailer, my truck, or any other vehicle.
X2!
I have on more than one occasion ended up with a blown tire on my vehicles due to road debris like nails screws and one was a bolt.. Fortunately, have never had a blow out on any of my trailers.
When it happens, slow down to a crawl until you can find a suitable spot (exit, driveway, parking lot) to pull off the road safely that does not have a steep drop off on the shoulder. As long as there is SOME rubber left on the rim it will generally be enough to protect the rim from severe damage IF you take your time.
Doesn't matter if you have single or dual axle, in both cases, the rim will hit the ground. Dual axles do not have any "edge" on this action as what happens is the good tire and axle will have to handle the full load, will be overloaded and the way dual axle spring suspensions work the axle with full weight will top out the spring travel limits and you will no longer have spring action.
Even if you did damage the rim in the process, it is replaceable, new rim is cheaper than replacing damaged axles and springs or repairing spring mounts.
