myredracer
Sep 27, 2014Explorer II
The glue for gluing ABS to PVC is called "transition" cement.
It's hard to tell without a photo but if the hole isn't too large, I would try an ABS coupling. Cut it in half lengthwise and sand down the ridge inside. Then just glue it over the hole (ABS glue). The pipe will be standard 2" or 1 1/2" ABS.
How do you get a hole in that?
44,066 PostsLatest Activity: Apr 15, 2026
